Part Numbers Index
Revision as of 00:29, 9 January 2012; view current revision
This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine
01
001 Engine 001 ENGINE ASSEMBLY (all NLA)
002 Engine Gasket Kit Repair Kit, Regrind Kit
003 Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN
* Timing Chain Cover, Cylinder Liner
004 Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT
005 Emission Control EMISSION CONTROL DEVICE
006 Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD
* flywheel, flex plate, cam bearings
007 Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN
008 Manifold MANIFOLD intake, exhaust
009 Exhaust Tube & Muffler -- See Below
009 Exhaust EXHAUST TUBE & MUFFLER
010 Oil Pump OIL PUMP & OIL STRAINER (oil filter)
011. Carburetor CARBURETOR(CRANK) with Manual Choke
011A Carburetor CARBURETOR(EXHAUST & EVAPO) with Manual Choke
011B DCH Carburetor CARBURETOR with Auto Choke
012 Air Cleaner AIR CLEANER To May 1971
013 See 018
014 Fuel Pump FUEL PUMP
015. Sedan Fuel Tank FUEL TANK(SEDAN)
015A Sedan Fuel Tank FUEL TANK(SEDAN EVAPO)
016. Coupe Fuel Tank FUEL TANK(COUPE)
016A Coupe Fuel Tank FUEL TANK(COUPE EVAPO)
018. Fuel Piping FUEL STRAINER & PIPING
018A Coupe (fuel filter & fuel lines)
019 Engine Control ACCELERATOR PEDAL & CHOKE CONTROL
020 Water Pump WATER PUMP & FAN
021 Radiator -- See Below
022 Engine Mounting -- See Below
Fuel
Raw Part Number List Fuel Part Numbers
Air Pollution Control
Vacuum Control (engine vacuum & breather hoses)
Carburetor
Carburetor, Twin
Fuel Throttle (See EGI fuel injection)
Fuel filter (fuel strainer) and Fuel Piping
Fuel Pump
Air Cleaner
Air Cleaner, GX
Fuel Tank & Fuel Piping -- See Below
Engine Electrical
See section Below.
Engine Control
Accelerator Linkage -- See Below
Choke Cable -- See Below
Chassis & Body
Radiator
Engine Mounting
Accelerator Linkage
Choke Cable
Power Train
Clutch Accessory
Clutch Control
Automatic Transmission
* Accessory
* Torque Convertor & Case
* Oil Pump & Clutch
* Planetary Gear
* Control Valve
* Control Switch
* Fitting
Manual Transmission
* Accessory
* 3-speed column shift
* 4-speed
* 5-speed (GX5)
* Transmission Case
* Transmission Gear
* Shift Control
* Transmission Control & Linkage
* Propeller Shaft
* Differential (Final Drive), Gear Carrier
Console Box -- See Below
Brake
Hand Brake (Parking Brake Control)
Front Brake
Rear Brake
Clutch & Brake Pedal
Brake master cylinder
Power Brakes
Brake Piping
Chassis
Front Axle
Rear Axle
Road Wheel & Cap
Steering Gear
Steering Column
Steering Linkage
Steering wheel
Steering Column Shell
Front Suspension
Rear Suspension
Spare Tire Carrier
Electrical
Section 20/02
Engine Electrical System
Distributor 023, 023A
Spark 024 HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG
Alternator Mounting (in Spark section)
Alternator & Regulator 025A, 025C
Alternator Accessory & Mounting
Starter Motor 026
Body Electrical System
* 027 Wiring Harness
Switch Part Numbers
* 028 SWITCHES FLASHER UNIT, HORN & CIGARETTE LIGHTER
* Electrical Unit, Instrument Switch & Relay
Meter
* 029A SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND)
* Instrument Panel
Room Heater & Ventilator 030, 030A, 030C
Radio & Clock
* 031 RADIO,ANTENNA & CLOCK
Battery
* 033 Battery & Battery Mounting
Wiper & Washer
* 034 WINDSHIELD WIPER, MOTOR & WIPER BLADE
* 035 WINDSHIELD WASHER
Head Light (head lamp)
* 036 HEAD LAMP
Front Combination Lamp Part Numbers
* 037 FRONT COMBINATION LAMP
Fog Lamp
Side Lighting
* 038 SIDE MARKER LAMP
* Side Reflectors
Sedan Rear Combination Lamp Part Numbers
* 039 REAR COMBINATION LAMP(SEDAN)
Coupe Rear Combination Lamp Part Numbers
* 39A REAR COMBINATION LAMP(COUPE)
License Lamp
* 040 LICENCE LAMP(SEDAN)
* 040A LICENCE LAMP(COUPE)
Room Lamp
041 ROOM LAMP
Body & Trim
Body Panels
Front Grille & Fitting
Rear Body
Bumper
Body Side Moulding & Stripes
Front Body Panels
Cowl & Dash Fitting
Cowl Top & Grille
Front Fender & Hood (bonnet)
Hood Lock Control
Dash, Side & Instrument Panel
Dash Fitting
Glove Box & Ash Tray
Side Panel & Lock
Glass
* Windshield
Roof Panel, Sunvisor & Mirror
Floor Panel & Fitting
Floor Mat, Carpet, Kicking Plate & Console Box
Body
 Body Side Panel & Rear Wheel House
 Body Side Fitting & Moulding
 Body Side Trimming
 Rear Fender & Panel
Glass
 Windshield
 Side Window
 Rear Window
Doors
 Front Door Panel, Glass & Door Ventilator
 Front Door Lock, Regulator & Handle
 Front Door Moulding, Finish & Arm Rest
Trunk Lid & Bumper
Trunk Room Trimming
Front Seat
Rear Seat & Tonneau Cover
Safety Belt & Head Rest
Miscellaneous
Keys & Cylinder
Badges (Emblem)
Blank Key
Model Number Plate
Touch-up Paint
Long Life Coolant & N.C.S. Sealer
Tool Kit
Special Tool
Vinyl Top (Leather Top)
