This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine
01 001 Engine 001 ENGINE ASSEMBLY (all NLA) 002 Engine Gasket Kit Repair Kit, Regrind Kit 003 Block & Pan CYLINDER BLOCK, FRONT COVER & OIL PAN * Timing Chain Cover, Cylinder Liner 004 Head CYLINDER HEAD, ROCKER COVER & THERMOSTAT 005 Emission Control EMISSION CONTROL DEVICE 006 Piston, Crank & Rod PISTON, CRANKSHAFT & CONNECTING ROD * flywheel, flex plate, cam bearings 007 Valvetrain CAMSHAFT, VALVE, SPROCKET & CHAIN 008 Manifold MANIFOLD intake, exhaust 009 Exhaust Tube & Muffler -- See Chassis section below 010 Oil Pump OIL PUMP & OIL STRAINER (oil filter) 011. Carburetor -- see Fuel section below 011A Carburetor, Exhaust Type -- see Fuel section below 011B Carburetor with Auto Choke -- see Fuel section below 012 Air Cleaner -- see Fuel section below 013 Fuel Strainer -- see Fuel section below 014 Fuel Pump -- see Fuel section below 015 Fuel Tank, Sedan -- see Chassis section below 016 Fuel Tank, Coupe -- See Chassis section below 018. Fuel Strainer, Sedan -- see Fuel section below 018A Fuel Strainer, Coupe -- see Fuel section below 019 Accelerator Pedal & Choke Control, see Chassis section below 020 Water Pump WATER PUMP & FAN 021 Radiator -- See Chassis section below 022 Engine Mounting -- See Chassis section below
Fuel
011. Carburetor CARBURETOR(CRANK) with Manual Choke 011A Carburetor CARBURETOR(EXHAUST & EVAPO) with Manual Choke 011B DCH Carburetor CARBURETOR with Auto Choke 012 Air Cleaner AIR CLEANER To May 1971 013 Fuel Strainer -- see 018 014 Fuel Pump FUEL PUMP 015 Fuel Tank, Sedan -- see Chassis section below 016 Fuel Tank, Coupe -- See Chassis section below 018. Fuel Piping FUEL STRAINER & PIPING Carburetor, Twin Air Cleaner, GX
Engine Electrical
Engine Control
Accelerator Linkage -- See Chassis section below Choke Cable -- See Chassis section below
Chassis & Body
Engine Support
009 Exhaust EXHAUST TUBE & MUFFLER 015. Sedan Fuel Tank FUEL TANK(SEDAN) 015A Sedan Fuel Tank FUEL TANK(SEDAN EVAPO) 016. Coupe Fuel Tank FUEL TANK(COUPE) 016A Coupe Fuel Tank FUEL TANK(COUPE EVAPO) 019 Engine Control ACCELERATOR PEDAL & CHOKE CONTROL 021 Radiator 022 Engine Mounting
Power Train
Clutch Accessory Clutch Control Automatic Transmission * Accessory * Torque Convertor & Case * Oil Pump & Clutch * Planetary Gear * Control Valve * Control Switch * Fitting Manual Transmission * Accessory * 3-speed column shift * 4-speed * 5-speed (GX5) * Transmission Case * Transmission Gear * Shift Control * Transmission Control & Linkage * Propeller Shaft * Differential (Final Drive), Gear Carrier Console Box -- See Below
Brake
Hand Brake (Parking Brake Control) Front Brake Rear Brake Clutch & Brake Pedal Brake master cylinder Power Brakes Brake Piping
Chassis
Front Axle Rear Axle Road Wheel & Cap Steering Gear Steering Column Steering Linkage Steering wheel Steering Column Shell Front Suspension Rear Suspension Spare Tire Carrier
Electrical
Section 20/02
Engine Electrical System
Distributor 023, 023A Spark 024 HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG Alternator Mounting (in Spark section) Alternator & Regulator 025A, 025C Alternator Accessory & Mounting Starter Motor 026
Body Electrical System
027 Wiring includes Wiring Harness 028 Switch * SWITCHES, FLASHER UNIT, HORN & CIGARETTE LIGHTER * Electrical Unit, Instrument Switch & Relay 029A Meter SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND) * includes instrument panel 030. Room Heater & Ventilator 030A Room Heater, Heavy Duty 030C Ventilator 031 Radio & Clock RADIO,ANTENNA & CLOCK 033 Battery & Battery Mounting 034 Wiper & Washer WINDSHIELD WIPER, MOTOR & WIPER BLADE 035 Wiper & Washer WINDSHIELD WASHER 036 Head Light HEAD LAMP 037 Front Combination Lamp Part Numbers FRONT COMBINATION LAMP 038 SIDE MARKER LAMP Side Lighting 039 Sedan Rear Combination Lamp REAR COMBINATION LAMP(SEDAN) 39A Coupe Rear Combination Lamp REAR COMBINATION LAMP(COUPE) 040 License Lamp LICENCE LAMP(SEDAN) 040A License Lamp LICENCE LAMP(COUPE) 041 Room Lamp ROOM LAMP (Dome Light)
Body & Trim
Body Panels
Front Grille & Fitting Rear Body Bumper Body Side Moulding & Stripes Front Body Panels Cowl & Dash Fitting Cowl Top & Grille Front Fender & Hood (bonnet) Hood Lock Control Dash, Side & Instrument Panel Dash Fitting Glove Box & Ash Tray Side Panel & Lock Glass * Windshield Roof Panel, Sunvisor & Mirror Floor Panel & Fitting Floor Mat, Carpet, Kicking Plate & Console Box
Body Body Side Panel & Rear Wheel House Body Side Fitting & Moulding Body Side Trimming Rear Fender & Panel Glass Windshield Side Window Rear Window Doors Front Door Panel, Glass & Door Ventilator Front Door Lock, Regulator & Handle Front Door Moulding, Finish & Arm Rest Trunk Lid & Bumper Trunk Room Trimming Front Seat Rear Seat & Tonneau Cover Safety Belt & Head Rest
Miscellaneous
Keys & Cylinder Badges (Emblem) Blank Key Model Number Plate Touch-up Paint Long Life Coolant & N.C.S. Sealer Tool Kit Special Tool Vinyl Top (Leather Top)
