Steering System Diagnoses
Revision as of 02:52, 12 April 2013; view current revision
Category: Steering System
The steering action in a stock Datsun 1200 should be very light. Use the information below to diagnose the problem you are having.
Definition: Diagnoses
Plural form of diagnosis
Heavy Steering
  • Stiction on steering column bearing or bush
    Lubricate the bearing, or replace the bushing
  • Wide tires
    Your choice. Wide tires will increase steering effort (you'll need to use more muscle to turn the wheel). This is usually only noticed at low speeds, as when trying to park.
  • Wrong Wheel offset
    Wheels offset to the outside will increase steering effort.
Loose Steering
  • Bad wheel alignment
    Peform Wheel alignment. Bad wheel alignment causes a variety of surprising behavior
  • Worn steering linkage (tie-rod ends, etc)
    Inspect and replace worn Steering Linkage parts
  • Steering gearbox not fastened securely to subframe
    Tighten Steering Gearbox bolts to specification
Pull to One Side
  • Front wheel bearings too tight
    Adjust Wheel bearings to specification
  • Front drum brakes: Unequal brake adjustment
    Perform Brake Adjustment procedure
  • Front disc brakes: Binding or frozen caliper
    Inspect the Front disc brakes on the side it pulls away from. This side is not working as good as the other side. Lubricate sliding parts or replace frozen caliper
  • Bad strut
    Inspect Strut and replace as needed
  • Bent or otherwise damage suspension component
    Inspect Front Suspension components
Steering Shock
If you feel sharp shocks through the body or steering wheel as you drive...
  • Front wheel bearings are adjusted too loose
  • Bent or otherwise damaged Front Suspension parts
    Inspect Front Suspension parts
  • Wheel out of balance
    If the shock increases with road speed, re-balance wheels. A shake in the steering wheel is another symptom of out-of-balance wheels
Double-tap Sound
When you drive over a bump, does the suspension make a double-knock sound?
  • Worn-out Idler Arm
    Replace the Idler Arm plastic bushings
