H165
Revision as of 04:29, 19 August 2013; view current revision
Category: Differential
Hitachi H165 differentials uses a 165mm (6.5") ring gear. One was fitted to Datsun 1200 Sunny Trucks (B120). Early (H165 pre-1973), H165B Type I (1973-1979) and H165B Type II (from July 1979). The gear sets do not interchange between the various Types.
[hide]
H165 has 8-stud removable center. H150 and H190 are also 8-bolt. H145 is 8-stud.
New Type uses M11 bolts, all others use M10 bolts.
H165 Chassis ID code is HC
Flange
174_5a58324e15d6b.jpgPost 487206
H150: 45 x 54 mm round or rectangular flange
There are some differences between flanges on H165's, some long (~217.5mm from carrier mounting face to driveshaft flange face), some short (~202.5mm). Depth of hole for centering boss varies also.
Size
Measure the gear
25277.jpgAlbum 25277
H145 measures 145mm
H150 measures 150mm
H165 measures 165mm
H190 measures 190mm
Pre-1980
  B10: H145, 3.900
 VB10: H145, 4.375 (van/wagon)
  B20: H145, 4.375 S.T.D. / 4.625 Optional (ute/pick-up)
 B110: H145 3.900
VB110: H145 4.111 (van/wagon)
PB110: H165 4.111
 B120: H165 4.111 (ute/truck)
 B210 1974: H145 3.900
 B210 1975-up: H150 3.700 or 3.889
PB210: H165
GB211: H165
 B310: H150 various
  A10: H165 various
1980-up
Axle Codes
H = Hitachi removable gear carrier (pumpkin/centre section)
HA - H145 (145mm diameter ring gear, 5.709 inch)
HB - H150 (150mm diameter ring gear, 5.906 inch)
HC - H165 (165mm diameter ring gear, 6.496 inch)
HD - H190 (190mm diameter ring gear, 7.480 inch) ALUMINUM CARRIER
HE - H190 CAST IRON CARRIER
HF - H190A revised for strength
21048.jpgAlbum 21048
Counting
24439.jpgAlbum 24439
39 divided by 11 = 3.545 ratio
25276.jpgAlbum 25276
Pinion gear is similarly stamped
25278.jpgAlbum 25278
Datsun Competition (later Nismo) used to sell various ratios:
  • H165B Type I (to 6/79): 3.545, 3.7, 3.9, 4.111, 4.375, 4.625, 4.875
  • H165B Type II (from 7/79): 3.364, 3.545, 3.7, 3.9, 4.111, 4.375, 4.625, 4.875
Available from production vehicles: 3.7, 3.9, 4.111 & 4.875 reference: diff ratios
1240.jpgC120 van ratios
You can get 4.1:1 and 4.875:1 ratios quite easy, it is the same diff that Bluebirds (rwd Maxima) and C20 (Datsun Vanette) -- some with aluminum centers -- and some 4wd Datsun Pickup (non-1200 ute) front diffs (those are wider assemblies, though, so just use the center section). For example: A10 Stanza/HL510 (1978-1982): 3.7:1 180B (610) wagon: 3.89:1 Series 1 Bluebirds (810): 3.89:1 Series 3 Bluebird wagon (910): 3.89:1
Pit Road carries the H165 part (LSD Nismo P/N 38420-RS110). [DatRats] also has been known to carry the 1200 ute stuff.
Ratios
H165 is available in:
3.364
3.545
3.700
3.900
4.111
4.375
4.625
4.875
Strength
H150 vs H165
Datsun 1200 Factory H165
Datsun B120 (1200 Sunny Truck) gear sets - H165 (HC41)
H165
* 38100-28500 4.111 HYPOID GEAR & PINION SET (37/9) (to '72-12)
H165B Type I carrier
* 38100-N5200 4.111 HYPOID GEAR & PINION SET (37/9) (from '73-1 to 7906)
H165B Type II carriers
* 38100-W9000 4.111 GEAR SET-FINAL DRIVE 7907-8605
* 38100-G3300 4.111 GEAR SET-FINAL DRIVE 8605-
Gasket
Center section gasket for H165 carrier.
  • 38320-N5000AS Gasket-carrier $4.27 USD
    • supersedes 38320-04110 GASKET-GEAR CARRIER H165
 8-stud: H145
 8-bolt: H165, H150
 9-bolt: Borg Warner 78 (locally assembled Datsun)
10-bolt: H190
23236.jpg H190_differential_cover_gasket.jpg th_M78_differential_cover_gasket.jpg
38320 GASKET-GEAR CARRIER
H145 38320-18010 GASKET-GEAR CARRIER $1.70 USD
H150 38320-H5001 Gasket-carrier $4.43 USD
H165 38320-04110 GASKET-GEAR CARRIER H165
H190 38320-B3002 Gasket-cover $4.13 USD
For more details, see main article: Diff Gasket
Alloy Carrier
The real advantage of an alloy diff is in the reduced unsprung mass, which is particularly important in a light car like a 1200.
Rare alloy H165 carrier - from 1967 Datsun 510 Bluebird (Series 1) Australia
Australia report: P410 & P411 Datsun Bluebirds & possibly even P310. These are pre 1600 models sold in the 1963 - '65 period. & are H165 diffs
Empty shell: Alloy 5.5 lb, Iron: 14.5 lb
USA Datsun Roadster - 1500 SP310, 3.88 ratio, 23 spline side gears
Nismo
LSD 2-way with 24 x 23T splines
H165: 38420-N5020 3.889 to 4.625 namiha 旧型
H165B low-tooth: 38420-N5020 3.700 to 4.875 並歯型
H165B high-tooth: 38420-RS110 3.154 to 4.875 高歯型
takaha
Nissan Competition
Also see H165 Conversion Listing
Page 29 of 1984 catalog
H165B RING & PINION SETS (TYPE I)
The ring and pinion sets listed below will fit the 710 (from 4/73), HL510 (to 6/79) and 200SX/S10.
38100-N4905 3.545 R&P SET
38100-N5000 3.700 R&P SET
38100-N5100 3.900 R&P SET
38100-N5200 4.111 R&P SET
38100-N5300 4.375 R&P SET
38100-N5400 4.625 R&P SET
38100-N5505 4.875 R&P SET
H165B RING & PINION SETS (TYPE II)
The ring and pinion sets listed below will fit the HL510 (from 7/79) and 200SX/S110 (to 6/81).
38100-W8600 3.364 R&P SET
38100-W8700 3.545 R&P SET
38100-W8800 3.700 R&P SET
38100-W8900 3.900 R&P SET
38100-W9000 4.111 R&P SET
38100-W9108 4.375 R&P SET
38100-W9208 4.625 R&P SET
38100-W9300 4.875 R&P SET
H165B LIMITED-SLIP ASSY
38420-N5020 L/S ASSY (TYPE I) 710 (from 4/73), HL510 (to 6/79) and 200SX/S10
38420-A1260 L/S ASSY (TYPE II) HL510 (from 7/79) and 200SX/S110 (to 6/81)
38423-N5020 SIDE GEAR (2)
38425-18000 PINION (4)
38427-21010 SHAFT
38431-21010 PRESSURE RING (2)
38432-21010 FRICTION PLATE (1.65MM) (4)
38433-21010 FRICTION DISC (1.65MM) (4)
38433-21011 FRICTION PLATE (1.90MM) (4)
38434-E4610 SCREW (4)
38435-21010 SPRING PLATE (1.65MM) (2)
38436-21010 SPRING PLATE (1.65MM) (2)
H165 AXLES BAFFLES
These baffles can be installed in any Datsun equipped with an H165 rear axles assembly.
pThey are designed to contain the differential oil in the center section.
43015-H7920 AXLE BAFFLE/RH
43016-H7920 AXLE BAFFLE/LH
DIFFERENTIAL OIL COOLER ASSY
21660-P9000 OIL PUMP ASSY
21664-P9000 BRACKET/OIL PUMP
21652-P9000 OIL COOLER ASSY
Swaps
Swapping an H165 into a 1200 can be great to match larger engine swaps. Sometime H165 is fitted because LSDs are more available for the H165 than for the H145 or H150.
See: Diff Widths
Datsun B110 (H145): 51.36 in (1305 mm) or 1185 mm axle flange-to-flange (less brakes)
Datsun B310 (H150): 53.5 in (1360 mm)
Datsun C20 Vannette: around 1400mm (105mm wider than a 1200)
Datsun V510: 53 in (H165 wagon)
Datsun A10 wagon (leaf type) 49" between backing plates.
* Estimated 53" axle wheel flange to flange.
The best swap candidate for Datsun 1200 is the H165 assembly from a Datsun 1200 Truck (B120). But they are not direct bolt-ins, as the spring mounts, shock mounts and brake lines/cables are slightly different. Some minor fabrication is needed.
Likewise for Datsun 510 axle swaps.
Datsun A10 axle is only 2 inches wider, so use positive offset (FWD) wheels to make up the difference. A10 has 4-link mounts, unless you get the wagon version which is leaf sprung.
200SX is 4-link, which brackets can be ground off and leaf pads added.
200SX, direct swap for B310 axle
Donor Cars
Available from production vehicles: 3.3, 3.5, 3.7, 3.9, 4.1, 4.4, & 4.875 reference: diff ratios
Australia
* A10 Stanza/HL510 (1978-1981): 3.700 and 3.875
* 180B (610) wagon: 3.889:1
* Bluebird 910 sedan: 3.889:1 and 3.700 (wagons used H190)
* 200B (810) wagon 4.111
  earliest versions before they switched to Borg Warner
* Series 3 Bluebird wagon (910): 3.889:1
* Bluebird series 1 (L20B engine)
* Bluebird series 2 (L20B engine)
C20 Vanette
C20 Ratios
3.889 V.SB.LD20
4.111 LD20
4.375 V.A15
4.875 T.A15, Z20
4.625 A15
5.143 A12
Namiha M10
Takaha M10
New Type M11
410
410 = C1 engine (998cc)
P410 = E1 engine (1189cc)
38320-04100 GASKET-gear carrier ALL
38100-04100 SET-GEAR, hypoid (41T:8T=5.125) S
38100-04101 SET-GEAR, hypoid (37T:8T=4.625) P,DF,L,N,DN
38100-08300 SET-GEAR, hypoid (35T:8T=4.375)
* U,LU,UN,LUN,WU,WLU,WUL,WLUN & 4 speed. SS
38100-09600 SET-GEAR, hypoid (37T:9T=4.111) (op) 4 speed. SS
S = Standard
D = Deluxe
F = Fancy
N = automatic clutch
L- = left hand drive
-L = handling package?
R = 2-door sedan
SS = Sport Sedan
SS-R = 2-dr Sport Sedan
U = export
W = Wagon
C1 = 2-bbl carb
E1 = 2-bbl Hitachi DAB-308-7
E1 = 2-bbl Nikki 2D-30CE <> 2D-30CE-2 Pedal clutch
E1 = 2-bbl Nikki Pedal clutch
E1 = 2-bbl Nikki 2D-30CF <> 2D-30CF-2 Automatic clutch
-K = SS = Twin Carburetor Hitachi HJE38W-1
SS = E1 (1200) Twin Carb
SSS = 411 R16 Twin Carb
SS = 411 J13 Twin Carb
411
411 J13 used H165
411 J16 used H190
P411 = J13
38320-04100 GASKET-gear carrier 1.3 <> 38320-04110
38100-13201 SET-GEAR, hypoid (35T:8T) 1.3l (except P-P)
38100-17901 SET-GEAR, hypoid (37T:8T) P-P [LPG]
38100-14301 SET-GEAR, hypoid (37T:9T) (op.) SS
H165
3.700 38100-N5000
3.889 38100-N5100
4.111 38100-N5200
4.375 38100-N5300
4.625 38100-N5400
4.875 38100-N5505
PB110 3.889
PB210 3.889, 4.111, 4.375
H165B
Namiha
GB211 3.700, 3.889
JP710(7306-)/JP711 3.889, 4.111
PA10 3.700
PA11(-7906) 3.700, 3.889
P810 3.889
PJ811 3.889, 4.111
S10/S11/PS110(-7906) 3.700, 3.889
C210/PC210 4.111, 3.889
C211(-7906) 4.111, 3.889
PC120(-8006) A12,A14 4.111, 4.375, 4.625, 4.875, 5.143
Takaha M10
PA11(7907-)/RA11(7907-) 3.700, 3.889
PJ910 3.889, 4.111
YJ910 3.889
PS110(7907-) 3.700, 3.889
JS12 MT 3.700, 3.889
PC211(7907-) 4.111, 3.889
FJR30 CA18S 3.700
FJR30 Z18 3.889
JF30 3.900, 4.111
PJC31 3.889
SJC31 4.111
PC120(8006-) A12,A14 4.111, 4.375, 4.625, 4.875, 5.143
C22 A15 4.375, 4.625, 4.875
3.154 38100-W8500
3.364 38100-W8600
3.545 38100-W8700 39/11
910 8401-8601 5F
3.700 38100-W8800 37/10
910 8210-8312
C31 8011-
R30 8210-
S110 7906- Z20E
S12 8308-8605
3.900 38100-W8900 35/9
910 7910-8605
C120 7907-
C31 8011-8210
R30 8108-8210
S110 7907- Z18
S110 8105- Z18E
4.111 38100-W9000
B120/B121 7907-8605
910 7910-8605
C120 7907-
C31 8011-
F30 8009-
S12 8308-8602
4.375 38100-W9100 35/8
C22 8509-8605
4.625 38100-W9200 37/8
C120 7907-
4.875 38100-W9300 39/8
C22 8509-8605 M10 RING GEAR BOLT
C120 7907-
New Type
M11 bolts
3.700 38100-G3100
M11 9508- (4WD.5P+4WD.7P).SR20DE
W10 9010-9301 4WD.GA16DS +4WD.SR20DE
W10 9301-9508 4WD.GA16DS +4WD.SR20DE
W10 9508- 4WD.GA16DS +4WD.SR20DE +SR20DET
910 8802-
S12 8605-
3.889 38100-G3200
910 8605 MT
4.111 38100-G3300
B120 8605-
910 8605- AT
910 8907- MT
4.375 38100-G3400
C22 8605-
TC22 8811- T.SB.A15S.MT +A15S.AT
4.625 38100-G3500
C22 8711-
C22 8711- V.A15
4.875 38100-G3600
C22 8605-
TC22 8811- A12S
North America
1500 Roadster
Datsun Fairlady 1500 roadster used an H165 diff. The 1600 and 2000 used a H190.
  • 38100-10400 SET-GEAR, hypoid drive (35 : 9) [3.889] SP310/SPL310
  • 38423-04101 GEAR-side, differential bevel (2)
410/411
1964-1965 PL410 = E1 engine (1200, 1189cc)
1966-1967 PL411 = J13 engine (1300)
RL411 (R16 engine) uses H190
38100-13201 (35/8=4.375) 3-speed OPTION
38100-13225 [4.625?] 3-speed
38100-14301 (37/9=4.111) 4-speed OPTION
38100-14325 4-speed
610
610 Wagons came with a leaf-sprung rigid axles with H165 differential.
38310-A6100 ASSY-CARRIER -0373
38310-N5000 ASSY-CARRIER 0473-
38310-N5000 ASSY-CARRIER AUTO 0873-
38100-29000 SET-HIPOID GEAR & PINION (35/9) -0373
38100-N5100 SET-HYPOID GEAR & PINION, 35/9 0473-0773
38100-N5100 SET-HYPOID GEAR & PINION, 35/9 (AUTO) 0873-0874
710
710 from 4/73 (TYPE I)
38100-N5100 SET-HYPOID GEAR & PINION, 35/9, 3.889 MANUAL -0874 WAGON
38100-N5000 SET-HYPOID GEAR & PINION, 37/10, 3.700 MANUAL 0974- WAGON
38100-N5200 SET-HYPOID GEAR & PINION, 37/9, 3.700 AUTO -0874 WAGON
38100-N5100 SET-HYPOID GEAR & PINION, 35/9, 3.889 AUTO 0974- WAGON
Sedan & Coupe
38100-29000 SET_HYPOID GEAR & PINION, 35/9, 3.889 MANUAL -0373
38100-N5100 SET-HYPOID GEAR & PINION, 35/9, 3.889 MANUAL 0473-0874
38100-28500 SET_HYPOID GEAR & PINION, 37/9, 3.700 AUTO -0373
38100-N5200 SET-HYPOID GEAR & PINION, 37/9, 3.700 AUTO 0473-0874
S10
1977-1978 Datsun 200SX TYPE I
38100-N5100 HYPOID SET-GEAR & PINION (35/9), 3.889 MANUAL
38100-N5000 HYPOID SET-GEAR & PINION (37/10), 3.700 AUTO
A10
1978-1981 Datsun 510
1979 3.545
1980 CAN 3.545
1980-1982 USA 3.364
1981-1982 CAN 3.367
to 6/79 TYPE I
from 7/79 TYPE II
  • 38100-N4905 HYPOID GEAR & PINION SET, 3.545 -0579
  • 38100-W8700 HYPOID GEAR & PINION SET, 3.545 -0679
  • 38300-W8600 FINAL DRIVE ASSY, 3.364 USA 0779-
  • 38300-W8700 FINAL DRIVE ASSY, 3.545 CANADA 0779-0680
  • 38300-W8600 FINAL DRIVE ASSY, 3.364 CANADA 0780-
These are very similar to the setup in the Datsun B310 (Sunny/210) and so are good swap donor for the Sunny. They come in 4-link for the sedan/coupe, same as Sunny sedan/coupe and all North America Datsun 210s.
S110
1979-1982 Datsun 200SX to 6/81
North American models were fitted with H190 starting in 7/81
H165 models
* 38100-W8800 GEAR SET-FINAL, 3.700 0179- Z20E+Z22E
* 38100-W8800 GEAR SET-FINAL, 3.700 0880- Z22E.MT
* 38100-W8900 GEAR SET-FINAL, 3.898 0880- Z22E.AT
Parts
Bearings
Also see: Axle Shaft for the rear wheel bearings
Differential
38440-61501 BEARING ASS'Y-diff side (2) $49 USD
* also used by S110 H165
* SKF BR30207 $30 USD
SKF BR30207 specifications
Tapered Bearing Cup & Cone Set
* I. D. mm 35 mm   (1.378")
* O. D. mm 72 mm   (2.835")
* Width mm 18.26mm (0.719")
Pinion Rear Support
38120-13201 BEARING ASS'Y-pinion rear $120 USD
* also used by:
  rear B12
  front 720,D21/D21U/WD21,D22U/WD22,S110,R50,S130/Z31
* SKF BR32306 $17
SKF BR32306 specifications
* I. D. 30 mm    (1.181")
* O. D. 72 mm    (2.835")
* Width 28.75 mm (1.132")
Pinion Front Support
38140-13201 BEARING ASS'Y-pinion front $82 USD
* also used by:
  front 720,D21/D21U/WD21,M10/M11,910,B12,S110,S12,S130
* SKF BR32305 $36 USD
SKF BR32305 specifications
* I. D. 25 mm   (0.984")
* O. D. 62 mm   (2.441")
* Width 24.25mm (0.994")
Side Gear
38423-28500 GEAR-SIDE B120, S110
38423-10600 GEAR-SIDE DIFF 1.3L 411
* superseded by 38423-28500
Part Sources
Bearings are available from Nissan, or from bearing supply companies
