Diff ID
Revision as of 11:10, 8 October 2019; view current revision
Spotters Guide: How to identify Datsun 1200 rear axle assemblies.
[hide]
ID
5944.jpgAlbum 5944
Flange
See Propeller_Shaft_Swaps#Flange
H145 36 x 50 scalloped
H150 45 x 54 rectangular or round
H165 same as H150, rectangular or round
H190 50 x 60
BW68 48 x 60
Bolt Pattern
H145 has 8-stud removable center. H150 and H165 also use 8 bolts. But only the H145 is 8-stud (the others use bolts).
H145 round 8-STUD
H150 round 8-bolt
H165 round 8-bolt
H190 round 10-bolt
BW   octagonal 8-bolt
Flange
174_5a58324e15d6b.jpgPost 487206
H150: 45 x 54 mm round or rectangular flange
There are some differences between flanges on H165's, some long (~217.5mm from carrier mounting face to driveshaft flange face), some short (~202.5mm). Depth of hole for centering boss varies also.
Size
Measure the gear
25277.jpgAlbum 25277
H145 measures 145mm
H150 measures 150mm
H165 measures 165mm
H190 measures 190mm
Pre-1980
  B10: H145, 3.900
 VB10: H145, 4.375 (van/wagon)
  B20: H145, 4.375 S.T.D. / 4.625 Optional (ute/pick-up)
 B110: H145 3.900
VB110: H145 4.111 (van/wagon)
PB110: H165 4.111
 B120: H165 4.111 (ute/truck)
 B210 1974: H145 3.900
 B210 1975-up: H150 3.700 or 3.889
PB210: H165
GB211: H165
 B310: H150 various
  A10: H165 various
1980-up
Axle Codes
H = Hitachi removable gear carrier (pumpkin/centre section)
HA - H145 (145mm diameter ring gear, 5.709 inch)
HB - H150 (150mm diameter ring gear, 5.906 inch)
HC - H165 (165mm diameter ring gear, 6.496 inch)
HD - H190 (190mm diameter ring gear, 7.480 inch) ALUMINUM CARRIER
HE - H190 CAST IRON CARRIER
HF - H190A revised for strength
21048.jpgAlbum 21048
Counting
24439.jpgAlbum 24439
39 divided by 11 = 3.545 ratio
25276.jpgAlbum 25276
Pinion gear is similarly stamped
25278.jpgAlbum 25278
BW
Australian-assembled B110 sedans used a Borg Warner Model 60 rear axle, starting in Late 1971. It has an octagonal gasket, instead of the round gasket of the Japan diffs. It is also a Salisbury type (non-banjo) so it has a bolt-on cover, while all Japan diffs have a bolt-in gear carrier.
See main article: Borg Warner Differential
11405.jpgAlbum 11405
H145
NOTE: Aussie-built B110 sedans with a non-removable diff center use the BW60 diff.
H145 is a Hitachi design with 145mm ring gear (5.71 inch).
B10 H145 uses a hand brake cross Rod -- a solid rod (B110 uses hand brake cables)
8110.jpgAlbum 8110
B110 H145 uses hand brake Cables (no rods)
9390.jpgAlbum 9390
Coupe
H150
See main article: H150
H150 was not fitted to Datsun 1200 orignally, but is common to have it swapped in. It looks like H145 (only 5mm larger), but has these major differences:
* H150 fastens to the axle housing with bolts instead of studs
* H150 orginally was fitted to 1975-1978 B210 and 1979-1982 B310
H165
H145: Vent to left of diff
H165: Vent to right of diff
H145 vs H165
18452.jpgAlbum 18452 1672.jpgAlbum 1672
21319.jpgAlbum 21319 21318.jpgAlbum 21318 21317.jpgAlbum 21317 20524.jpgAlbum 20524 1660.jpgAlbum 1660
Brake Line Split
1200
splitter is on right side of RHD coupe & sedan
splitter is on left side of RHD ute
splitter is near center of LHD coupe & sedan
Flexible Hose (from chassis to rear axle) is the same RHD/LHD. Splitter is the same.
Shock Mount
See main article: Leaf Springs
Sedan vs Coupe: sedans have a shock bracket for the axle housing, which coupes lack.
24932.jpgAlbum 24932
Sedan mount
14584.jpgAlbum 14584
Coupe/van/truck
174_54d5aa409d1da.jpgPost 463507
Bound Bumpers
1200 Coupe/van/truck has bound bumpers
11171.jpgAlbum 11171
1200 Sedan does not have this, as the bound bumper is built into the top of the shock absorbers.
24801.jpgAlbum 24801
Brake Adjusters
See main article: Rear Brakes
B110, B120 to 1989, B210 has manual adjuster
24997.jpgAlbum 24997 21654.jpgAlbum 21654
B120 from 1989 (H165) has star-wheel auto-adjuster
19112.jpgAlbum 19112
B310 (H150) A14/A15 adjuster assembly (automatic with star wheel)
24996.jpgAlbum 24996
