<-- back to Part Numbers Index
Also see: Main articles for usage, photos, cross-reference: Headlights Lighting System
Applied Model Codes
041 designed for Datsun 310
087 designed for Datsun 320 light truck
148 designed for Datsun 520 light truck
180 designed for Datsun B10 introduction (1966)
580 designed for Nissan Diesel 680ᴳ
H10 designed for 1200 STD
H16 designed for LB110ST (1970.5 Okinawa)
899 common Nissan part (not model-specific)
Head Lamp To 8910
08310-40182 SCREW (3 per side)
HEAD LAMP - ICHIKO 26010-H1000 LAMP ASS'Y-head (R.H.) (市光) -8910 26060-H1000 LAMP ASS'Y-head (L.H.) (市光) -8910 26010-H1600 LAMP ASSY-HEAD,RH -8503 IKI FOR OKINAWA 1 26705-04101 UNIT-sealed beam 26705-89920 HEAD LAMP UNIT IKI -8910 26705-89925 HEAD LAMP UNIT IKI F/OKINAWA -8503 2 26022-H1000 SCREW-adjust 4 3 26023-H1000 NUT 4 4 26024-58000 SPRING 2 26024-H1000 SPRING 2 <> 26024-58000 5 26017-14801 RING-retaining IKI -8910
HEAD LAMP - KOITO 26010-H1011 LAMP ASS'Y-head (R.H.) (小糸) -8910 26010-H1010 LAMP ASS'Y-head (R.H.) (小糸) -8910 26010-H1611 LAMP ASSY-HEAD,RH -8503 KOITO F/OKINAWA 1 26705-08700 UNIT-sealed beam 26705-89900 HEAD LAMP UNIT KOITO -8910 26705-89906 HEAD LAMP UNIT KOITO F/OKINAWA -8503 2 26022-H1010 SCREW-adjust 4 3 26023-H1010 NUT-ADJUSTING SCREW 4 4 26024-H1010 SPRING 2 26024-H1011 SPRING 2 <> 26024-H1010 5 26017-18011 RING-retaining 2 26017-89910 RING-RETAINING KOITO -8910 2
Head Lamp From 8910
Applied Model Codes
G12 designed for B120STU (1971)
V60 designed for unknown
W76 designed for Auster Z16/Z18
01P designed for (?) Z31 Fairlady Z
C99 ¿Nissan electric parts?
カク2トウ ヨウ 商113 [Rectangular 2 unit IKI part] 26010 LAMP ASSY-HEAD,RH 26010-G1265 8910- 26010F GROMMET-SCREW 26399-V6000 8910- 4 26011 HEAD LAMP UNIT 267705- C9920 8910- 2 26016 RIM-MOUNTING,NO.1 RH 26016-G1265 8910- 26018 RIM-MOUNTING,NO.1 LH 26018-G1265 8910- 26022 SCREW-ADJUSTING 26022-G1265 8910- 4 26023 RING-RETAINING 26017-W7600 8910- 2 26023A SCREW 26601-01P00 8910- 8 26024 SPRING-TENSION 26024-G1265 8910- 26060 LAMP ASSY-HEAD,LH 26060-G1265 8910- 26800N COVER-HEAD LAMP 26029-89900 8910-
Applied Model Codes
H19 designed for B110 LHD (USA, Canada)
042 designed for Datsun 310 LHD
A46 designed for 510.L16 (1970)
1 26010-H1611 ASSY-LAMP HEAD RH(KOITO) 2 26010-H1610 1 26010-H1610 ASSY-LAMP HEAD RH(KOITO) 1 26010-H1600 ASSY-LAMP HEAD RH(ICHIKHO) 1 26010-H1900 ASSY-LAMP HEAD RH(ICHIKHO) 0570- 2 26010-H1600 2 26060-H1600 ASSY-LAMP HEAD LH(ICHIKHO) 2 26060-H1900 ASSY-LAMP HEAD LH(ICHICHO) 0570- 2 26060-H1600 2 26060-H1610 ASSY-LAMP HEAD LH(KOITO) 3 26705-89905 UNIT-SEALED BEAM (KOITO) 2 3 26705-04201 UNIT-SEALED BEAM (ICHIKHO) 2 3 26705-89925 UNIT-SEALED BEAM (ICHIKHO) 2 2 26705-04201 4 26022-H1010 SCREW-ADJUST(KOITO) 4 4 26022-H1000 SCREW-ADJUST(ICHIKHO) 4 $1.62 USD 5 26023-H1000 NUT(ICHIKHO) 4 $1.45 USD 5 26023-H1010 NUT(KOITO) 4 6 26024-58000 SPRING(ICHIKHO) 2 $1.43 USD 6 26024-H1000 SPRING (ICHIKHO) 2 0670- 2 26024-58000 6 26024-H1010 SPRING(KOITO) 2 6 26024-H1011 SPRING(KOITO) 2 2 26024-H1010 7 26017-14801 RING-RETAINING(ICHIKHO) 2 7 26017-18010 RING-RETAINING(KOITO) 2 8 26029-A4601 COVER-TERMINAL 2 0570- 2 26029-A4600 $6.45 USD 8 26029-A4600 COVER-TERMINAL 2 RIM-MOUNTING [head lamp bucket, not available separately]
