Search results
For query "Seals"
There is no page titled ":Seals". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Valve Seals (6071 bytes)
    1: ...0s were fitted with '''valve shrouds''' (umbrella seals) on the intake valves. Later A-series engines mov...
    4: ...-rings, but later 1200s were fitted with umbrella seals on the intake valves.
    7: Aftermarket seals come in various types, as this [http://mgaguru.co...
    8: ...{{ExtPhoto|http://mgaguru.com/mgtech/engine/pics|vseals_b.jpg}}
    11: ...{Post|326267}} diymark]: I used the positive type seals on the inlet so oil doesn't get sucked in under v...
  2. Transmission Seals (4147 bytes)
    1: {{BackTo|56-Series Transmission Parts|Seals}}
    3: Rubber seals for gearbox.
Page text matches
  1. Engine Gasket Kit (2904 bytes)
    22: * [[Valve Seals]]
    26: Other Seals Included in Engine Kit
    27: * [[Timing Cover]] gaskets & Seals
    31: * [[Crankshaft]] seals
  2. A12GX Engine (12809 bytes)
    77: * Different valve stem oils seals (Option on standard A12)
  3. Malaysia (1316 bytes)
    1: ...s of varying quality, like Datsun 1200 badges and seals, which can be found on eBay.
  4. 56-Series Transmission Parts (14523 bytes)
    10: Typical rebuild replacement parts (Seals, bearings and synchro rings)
    27: SEALS
    326: == Seals ==
    331: {{Main|Transmission Seals}}
    336: {{Main|Transmission Seals}}
  5. Strut (11961 bytes)
    12: ...ebuildable oil filled tube with shock valving and seals. Later, Nissan come out with Strut "inserts", a s...
    87: ...if you can find the rebuild kit, just replace the seals etc. and put in new fluid. The alternative is a "...
    93: As long as the o-ring seals aren't dried-out or cracked, no rebuild kit is ne...
  6. Fuel Requirements (12778 bytes)
    117: * Alcohol-resistant fuel lines and parts (seals, etc)
  7. Valve adjustment (7052 bytes)
    6: ... any valve parts are changed or loosened ([[Valve Seals]], [[Rocker arms]], [[Rocker Shaft]], etc.)
  8. Crankshaft (8631 bytes)
    172: = Seals =
  9. Oil pan (12094 bytes)
    52: The splash pan seals the underneath of the chassis at the front of the...
    264: * 99996-H1135 SPECIAL OIL PAN GASKET Seals better than the stock gasket and can be reused wh...
  10. Hydraulic clutch (7979 bytes)
    53: If the master is bad, replace it. Or a kit (new seals) can be installed.
  11. Wipers (8777 bytes)
    184: == Pivot Seals ==
  12. Glass (11375 bytes)
    33: === Rubber Seals ===
    46: * 221.101 Quarter window seals - front (coupe) LH
    47: * 221.102 Quarter window seals - front (coupe) RH[/quote]
    93: === Rubber Seals ===
  13. Rubber parts (4528 bytes)
    1: ... weatherstripping, pedal pads, door seals, window seals
    23: = Engine Seals =
    28: [[Oil pan]] front & rear seals
    49: See main article: [[Windshield#Rubber_Seals]]
    71: [[Glass#Rubber_Seals|Door Ventilator]] (quarter glass)
  14. Aftermarket (1669 bytes)
    11: ...lock, crank, & rods, but not the pistons rings or seals. Even the head may be a 'genuine' item, but they ...
  15. Automatic Transmission (17258 bytes)
    326: ...ntains Friction and Steel Clutch Plates, Gaskets, Seals, O-Rings and Sealing Rings) $108.99
  16. Rear Disc Brakes (7561 bytes)
    52: ...nd rotors from an 82-83 280ZX, as well as new oil seals for the axles, wheel bearings, etc. It's pretty s...
  17. Balljoint (2915 bytes)
    26: ... the rubber seal. No big deal, as you can buy the seals separately.
  18. Muffler (11093 bytes)
    90: To make sure the exhaust seals, use the factory Datsun muffler seal in the exhau...
  19. Water pump (9463 bytes)
    239: ...l. Don't ever run the pump dry, they have ceramic seals in them that don't like to be run dry.<br><br>I'v...
  20. Oil cap (5899 bytes)
    1: ...'''oil cap'''. It is a classic all-chrome cap and seals with a simple round gasket. Some other Datsuns us...
Search in namespaces :
List redirects   Search for
