This is a article index of Nissan Part Numbers for Datsun 1200. Note that discontinued (NLA) parts form Nissan can sometimes be found on eBay or from individual stores (NOS or "New Old Stock").
Use the SEARCH box at the FAR bottom of this page (scroll down) to search for specific parts.
Or click through the Index below.
Engine & Engine Control
Engine
Raw Parts List Engine Part Numbers
Engine Engine assembly (all NLA) Engine Gasket Kit Cylinder Block & Oil pan Timing Chain Cover -- See "Front Cover" Below Cylinder Liner Cylinder Head & Rocker Cover Engine Mounting Connecting Rods Piston & Crankshaft & Flywheel Front Cover & Cylinder Fitting Camshaft & Timing Chain & Valve Mechanism Manifolds EGR Emission Controls Oil pump & Oil filter (oil strainer) Exhaust Tube & Muffler -- See Below Water pump & Thermostat Radiator -- See Below
Fuel
Raw Part Number List Fuel Part Numbers
Air Pollution Control Vacuum Control (engine vacuum & breather hoses) Carburetor Carburetor, Twin Fuel Throttle (See EGI fuel injection) Fuel filter (fuel strainer) and Fuel Piping Fuel Pump Air Cleaner Air Cleaner, GX Fuel Tank & Fuel Piping -- See Below
Engine Electrical
See section Below.
Engine Control
Accelerator Linkage -- See Below Choke Cable -- See Below
Chassis & Body
Radiator Engine Mounting Fuel Tank & Fuel Piping Accelerator Linkage Choke Cable Exhaust Tube & Muffler
Power Train
Clutch Accessory Clutch Control Automatic Transmission * Accessory * Torque Convertor & Case * Oil Pump & Clutch * Planetary Gear * Control Valve * Control Switch * Fitting Manual Transmission * Accessory * 3-speed column shift * 4-speed * 5-speed (GX5) * Transmission Case * Transmission Gear * Shift Control * Transmission Control & Linkage * Propeller Shaft * Differential (Final Drive), Gear Carrier Console Box -- See Below
Brake
Hand Brake (Parking Brake Control) Front Brake Rear Brake Clutch & Brake Pedal Brake master cylinder Power Brakes Brake Piping
Chassis
Front Axle Rear Axle Road Wheel & Cap Steering Gear Steering Column Steering Linkage Steering wheel Steering Column Shell Front Suspension Rear Suspension Spare Tire Carrier
Electrical
Section 20/02
Engine Electrical System
Distributor 023, 023A Spark 024 HIGH TENSION CABLE, IGNITION COIL & SPARK PLUG Alternator Mounting (in Spark section) Alternator & Regulator 025A, 025C Alternator Accessory & Mounting Starter Motor 026
Body Electrical System
Wiring * 027 Wiring Harness Switch Part Numbers * 028 SWITCHES FLASHER UNIT, HORN & CIGARETTE LIGHTER * Electrical Unit, Instrument Switch & Relay Meter * 029A SPEEDOMETER, COMBINATION METER & FLEXIBLE SHAFT(ROUND) * Instrument Panel Room Heater & Ventilator 030, 030A, 030C Radio & Clock * 031 RADIO,ANTENNA & CLOCK Battery * 033 Battery & Battery Mounting Wiper & Washer * 034 WINDSHIELD WIPER, MOTOR & WIPER BLADE * 035 WINDSHIELD WASHER Head Light (head lamp) * 036 HEAD LAMP Front Combination Lamp Part Numbers * 037 FRONT COMBINATION LAMP Fog Lamp Side Lighting * 038 SIDE MARKER LAMP * Side Reflectors Sedan Rear Combination Lamp Part Numbers * 039 REAR COMBINATION LAMP(SEDAN) Coupe Rear Combination Lamp Part Numbers * 39A REAR COMBINATION LAMP(COUPE) License Lamp * 040 LICENCE LAMP(SEDAN) * 040A LICENCE LAMP(COUPE) Room Lamp 041 ROOM LAMP
Body & Trim
Body Panels
Front Grille & Fitting Rear Body Bumper Body Side Moulding & Stripes Front Body Panels Cowl & Dash Fitting Cowl Top & Grille Front Fender & Hood (bonnet) Hood Lock Control Dash, Side & Instrument Panel Dash Fitting Glove Box & Ash Tray Side Panel & Lock Glass * Windshield Roof Panel, Sunvisor & Mirror Floor Panel & Fitting Floor Mat, Carpet, Kicking Plate & Console Box
Body Body Side Panel & Rear Wheel House Body Side Fitting & Moulding Body Side Trimming Rear Fender & Panel Glass Windshield Side Window Rear Window Doors Front Door Panel, Glass & Door Ventilator Front Door Lock, Regulator & Handle Front Door Moulding, Finish & Arm Rest Trunk Lid & Bumper Trunk Room Trimming Front Seat Rear Seat & Tonneau Cover Safety Belt & Head Rest
Miscellaneous
Keys & Cylinder Badges (Emblem) Blank Key Model Number Plate Touch-up Paint Long Life Coolant & N.C.S. Sealer Tool Kit Special Tool Vinyl Top (Leather Top)
