1984 Nissan Competition Catalog
Revision as of 19:46, 15 December 2014; view current revision
Category: Nismo
ALL 1200-related Pages from 1984 Catalog
Proven names like Electromotive, Bob Sharp Racing, Tilton, Koni, Venolia and Iskenderian, backed by a complete line of non-USA [JDM] and competition parts from the factory make this the most comprehensive competition catalog ever.
For other catalogs, see Nissan Competition
th_Competition198400.jpg NISSAN COMPETITION PARTS
Table of contents:
  • 1200, B210, 210, 310/N10 Page 34 [sic, page 36]
  • Miscellaneous Page 60
1200 Parts
Piston and Camshaft
Cylinder Head, Valves and Lubrication
Cooling
Hitachi Twin Carb
The GX/SU induction system was a production line option on non-USA versions of the 1200 and B210. Requires use of GX cylinder head. The GX system can be adapted to virtually any A-series engine.
Pulleys and Electrical
Tachometer, Speedometer and Exhaust
Flywheel, Clutch and Transmission
Differential
Stabilizer and Shocks
  • F10 & N10/310 Final Drive Gears (To 7/81)
  • Wheel Studs & Nuts
  • Brakes
    • 99996-H7010 1200, F10 & 310/N10 DP11 BRAKE PAD SET
    • 99996-K7000 B210 & 210 DP11 BRAKE PAD SET
    • 44060-27720 BRAKE SHOE/FORE for 1200 and early B210
    • 44070-27720 BRAKE SHOE AFT for 1200 and early B210
    • 44060-A1270 BRAKE SHOE/FORE for late B210, 210, F10 & 310/N10
    • 44070-A1270 BRAKE SHOE/AFT for late B210, 210, F10 & 310/N10
    • 44100-H3320 5/8" WHEEL CYLINDER for 1200 and early B210
    • 44100-H3300 11/16" WHEEL CYLINDER for 1200 and early B210
    • 44100-H3100 13/16" WHEEL CYLINDER for 1200 and early B210
    • 44100-M7000 5/8" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-M4901 11/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-G2800 3/4" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-U9200 13/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-N4601 7/8" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-Q1100 15/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-A7610 1" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
    • 44100-A7611 1-1/16" WHEEL CYLINDER for late B210, 210, F10 & 310/N10
  • 1200 Stabilizer Bars
    • 54611-H2300 20MM FRONT BAR
    • 54617-H2300 BUSHING FOR 54611-H2300 2 REQ.
    • 99996-H4301 QUICKOR 25MM FRONT BAR KIT
    • 99996-H4351 QUICKOR 19MM REAR BAR KIT
  • B210 Stabilizer Bars
    • 54611-22301 19MM FRONT BAR
    • 54617-22020 BUSHING FOR 54611-22301 2 REQ.
    • 99996-H4060 INSTALLATION KIT FOR 54611-22031
    • 54611-22030 23MM FRONT BAR
    • 54617-22030 BUSHING FOR 54611-22030 2 REQ.
    • 99996-H4060 INSTALLATION KIT FOR 54611-22030
  • 210 [Datsun B310] Stabilizer Bars
  • 310/N10 Stabilizer Bars
  • Koni Shock Absorbers
    • Front
    • Rear
    • 99996-1714N 1200/FRONT 2 REQ.
    • 99996-2359A 1200/REAR (COUPE ONLY) 2 REQ.
    • 99996-1912R B210/FRONT
    • 99996-2359A B210/REAR (COUPE ONLY)
    • 99996-2002P 210/FRONT
    • 99996-2378B 210/REAR (EXCEPT WAGON)
    • 99996-1130B 210/REAR (GAS)(EXCEPT WAGON)
    • 99996-2002T 210/FRONT (SPORT)
    • 99996-2378J 210/REAR (SPORT)(EXCEPT WAGON)
    • 99996-2005P F10 & 310/N10/FRONT
    • 99996-2205B F10 & 310/N10/REAR
Suspension and Fiberglass Parts
  • 1200 Coupe Racing Suspension System
  • B210 Coupe Racing Suspension System
  • 210 Racing Suspension System
  • 210 Misc. Suspension Components
  • 310/N10 Coupe Racing Suspension System
  • 1200 Coupe Factory Fiberglass Parts
  • B210 GT4 Fiberglass Parts
  • 210 Fiberglass Parts
Miscellaneous
Mikuni Accessories
  • Mikuni/Solex Accessories
    • Main Jets
    • Air Jets (Countersunk Type)
    • Pilot Jets
    • Outer Venturi (40PHH)
    • Outer Venturi (44PHH)
    • Needle Valve ASSY
    • Velocity Stack
  • Mikuni/Solex Accessories [continued]
    • Jet Blocks
    • Main Bleed Pipe (Emulsion Tube)
Spark Plugs
Note: Non-resistor plugs can be used in racing, where allowed. Resistor plugs are used in street cars as they do not interfere with radio communications.
  • Champion Spark Plugs
    • 99996-00N60 N60 REGULAR TIP SPARK PLUG [B9ES equivalent]
    • 99996-00N2G N2G GOLD TIP SPARK PLUG [B9EVX equivalent]
    • 99996-0N59G N59G GOLD TIP SPARK PLUG [B95EGV equivalent]
    • 99996-0N57G N57G GOLD TIP SPARK PLUG [B105EGV equivalent]
    • 99996-0N10Y N10Y PROJECTED TIP SPARK PLUG
    • 99996-00N9Y N9Y PROJECTED TIP SPARK PLUG [BP6ES equivalent]
    • 99996-00N8Y N8Y PROJECTED TIP SPARK PLUG
    • 99996-00N7Y N7Y PROJECTED TIP SPARK PLUG [BP7ES equivalent]
    • 99996-00N6Y N6Y PROJECTED TIP SPARK PLUG [BP8ES equivalent]
    • 99996-0N60Y N60Y PROJECTED TIP SPARK PLUG [BP10ES equivalent]
  • Spark Plug Spacer
    • 99996-N6732 .096 SPARK PLUG SPACER
    • 99996-0N677 .135 SPARK PLUG SPACER
Special Tools
  • Special Tools
    • EG167-00000 UNI-SYN CARB ADJUSTMENT GAUGE
    • ST358-50000 BRAKE ADJUSTMENT TOOL
Literature
Labels
  • Nissan/Datsun Die-cuts & Labels
    • 99996-X1001 'DATSUN' BLACK (1.5" x 12")
    • 99996-X1002 'DATSUN' WHITE (1.5" x 12")
    • 99996-X1003 'NISSAN' BLACK (1.5" x 12")
    • 99996-X1004 'NISSAN' WHITE (1.5" x 12")
    • 99996-X1010 'DATSUN' BLACK (3.5" x 34")
    • 99996-X1011 'DATSUN' WHITE (3.5" x 34")
    • 99996-X1013 'NISSAN' BLACK (3.5" x 34")
    • 99996-X1014 'NISSAN' WHITE (3.5" x 34")
    • 99996-X2001 'DATSUN...WE ARE DRIVEN' BLACK
    • 99996-X2002 'DATSUN...WE ARE DRIVEN' WHITE
    • 25371-N3121 IGNITION CUT-OFF SWITCH LABEL (CIRCLE)
    • 25371-A7600 IGNITION CUT-OFF SWITCH LABEL (TRIANGLE)
Wearing Apparel
  • Wearing Apparel
    • T-shirts
    • Tank Tops
    • Halter Top
    • Patches
Posters
  • Posters
    • 99996-P0003 '74 B210 C/S
    • 99996-P0006 '76 B210 C/S
    • 99996-P0012 '77 B210 C/S
    • 99996-P0013 '77 B210 IMSA RS
    • 99996-P0014 Z/B210 IMSA
    • 99996-P0017 '78 B210 C/S
    • 99996-P0020 '79 B210 C/S
Poster Gallery
